Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > Best bang for the buck 4ch amp
Author Thread: Best bang for the buck 4ch amp
I need a 4 ch amp that puts out 40-50 watts RMS\channel 4ohm. I don't want to spend an arm and a leg. My speakers are 40 watt RMS. Please help.
Username: Chevy_for_life
Post Number: 63
type into google sucky @$$ amp and it will bring one up for you
unregistered
dude ive been on a bunch of posts and i think these are supposed to help ppl so where does bowtie get off bashing everything? how bout u just be a normal person and help ppl out instead of being an a$$.
Post Number: 77
dude i dont bash eveyone i just tell you how it is typically.. like how sony sucks and Boss and pyramid.. and i do help people every once in awhile..
Post Number: 79
Kicker 04KX200.4 ...4 channel amp that puts out 50x4 for $160...http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13893
Post Number: 87
dose that help you any Duane??? is is that still to much it gots free shipping
DuaneB
Thanks. I ended up buying a MTX thunder4244 off ebay for $61 plus ship. From what I read its not a bad amp for the money I spent. Its 45x4 and they say is underrated.
Post Number: 90
yes i've herd that MTX is underrated
Username: Glasswolf
NorthWest, Michigan
Post Number: 4639
the kicker and mtx are both good amps.
about on par with each other.
Home > Message Board > Car Audio > Amplifiers > Archive through October 19, 2004 > Best bang for the buck 4ch amp [ « Previous ] [ Next » ]
