Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Xover Settings
Author Thread: Xover Settings
Username: Mdale007
I upgraded my '04 Altima head unit to a new Alpine CDA-9833 with the i-Personalize.
My question concerns the Xover settings for the following stock speakers.
The rear 6 X 9's (Xover to -3db 80hz 24db/oct)
The front 5-1/4 and tweeters (Xover to -3db 125hz 12db/oct)
If I am correct these Xover settings should prevent distortion?
I do not understand phasing and I do not have a sound meter.
I would like to know if these settings especially the slopes are correct?
Username: Glasswolf
NorthWest, Michigan
Post Number: 4561
that's about where I'd set them myself.
looks good.
leave phase at -0 (zero)
Username: Mdale007
GlassWolf thanks for the information concerning leaving the phase a -0.
Can you direct me on how to use the 5-Band Parametric EQ?
Username: Glasswolf
NorthWest, Michigan
Post Number: 4584
I can show ya a page on parametric EQs and what they do..
how to set the Alpine's is all in the manual for the unit.
it takes a little fumbling to get used to setting it, but a parametric is set-and-forget.
once it's set you leave it alone.
http://www.bcae1.com/equalizr.htm
Username: Gstern1994
Thanks a million guy's, had the same questions about my 9833. Sounds Terrific now.
Home > Message Board > Car Audio > EQs and Crossovers > Archive through March 29, 2005 > Xover Settings [ « Previous ] [ Next » ]
