Thread: Zapco symbilink |
Bronze Member Username: Ha_split_lf
Post Number: 12 Registered: Oct-04
| Posted on Tuesday, October 12, 2004 - 03:18 pm: |
i just got a zapco 500.1 amplifier and it comes with the symbilink. however both the cable they give and the amp are female ports where can i buy a male/male wire online, or would it be possible to use another wire say from a computer store? just curious becasue there are no zapco dealers in my area and i would like to get the amp in ASAP! |
Gold Member Username: Jonathan_f
GA
Post Number: 2240 Registered: May-04
| Posted on Tuesday, October 12, 2004 - 04:04 pm: |
Yeah, it's just firewire cable. |
Post Number: 13 Registered: Oct-04
| Posted on Tuesday, October 12, 2004 - 05:52 pm: |
sweet thank you very much. |
Post Number: 14 Registered: Oct-04
| Posted on Tuesday, October 12, 2004 - 06:00 pm: |
wait are there more than one kind firewire? all the firewire cables i have are square/rectangle type shapes. however the symbilink is round and has six pins. kind of shaped more like s-video. or is it just firewire cable with different connecting pins? |
GA
Post Number: 2247 Registered: May-04
| Posted on Tuesday, October 12, 2004 - 06:58 pm: |
Let me clarify, it's Firewire technology, but commonly referred to as DIN cable. Can't remember if Zapco uses a special type, but go to the shop, take your female cable, and they should find one to fit it if they have it. You can find many online as well, such as here: http://www.cablestogo.com/resources/din.asp |
Silver Member Username: Fishy
Tamarac,
FL
Post Number: 513 Registered: Sep-04
| Posted on Tuesday, October 12, 2004 - 09:39 pm: |
Yeah alot of car audio manufacturers used to use din cables. Don't go by this exact wiring pin out, but here's PPI's old phantom power setup. http://www.precisionpower.net/ppipdfs/plugs/dinplu1.pdf If what you have looks like that then any din gender changer/cable should work. Radio Shack might even have something. Yeah take your female cable to Radio Shack and see if this works for $6.29. http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=42-2151 It should unless you have a mini din plug(the size of a PS/2 mouse connector) and they should have something for that size as well. Like this http://www.radioshack.com/product.asp?catalog%5Fname=CTLG&product%5Fid=980-0671 good luck -Fishy
Post Number: 15 Registered: Oct-04
| Posted on Wednesday, October 13, 2004 - 12:52 am: |
ahh thank you very much for clarifying that one. im pretty new with this stuff that is greatly appreciated! |
NorthWest,
Michigan
Post Number: 4556 Registered: Dec-03
| Posted on Wednesday, October 13, 2004 - 10:28 am: |
*cough* yeah PPI got that from Orion. they were interchangable back then. I still use Orion amps and signal processing with their DIN cables. excellent noise rejection with a balanced signal path, and a nice high signal voltage.
