Thread: Whats wrong with my amp |
Unregistered guest |
| Posted on Monday, October 11, 2004 - 07:12 pm: |
i have a concept amp, and i was using it bridged to power to JL w-0 12's. Then one day it stopped working, the power light is on green which means its ok, so i unbridged them and hooked them up normally, they worked fine until a day later, when it stopped workin agagin (no sound), so are my outputs blown? or is there something else wrong. Anyone with any advice would help. thanx ALOT!! Oh and i also unhooked the amp and hooked up a different one and it works fine, so i'm pretty sure the wiring and fuses are ok. Thanx again. |
NorthWest,
Michigan
Post Number: 4524 Registered: Dec-03
| Posted on Monday, October 11, 2004 - 09:18 pm: |
well it sounds like the amplifier failed. you could get it serviced, or replace it.
| Posted on Monday, October 11, 2004 - 10:35 pm: |
do you have any idea to how much it would cost to get it serviced? thanx |
NorthWest,
Michigan
Post Number: 4546 Registered: Dec-03
| Posted on Tuesday, October 12, 2004 - 12:53 pm: |
is it under warranty?
