Thread: JBL 180.2 stopped working |
| Posted on Monday, October 11, 2004 - 01:17 pm: |
Hey, I really need some help. First, heres a rundown of my system: Alpine 9827 CDT cl-61 powered by JBL 180.2 2 x Adire Shiva powered by JBL 1200.1 KnuKonceptz wires Everything was working nicely for about a month or so, until I was turning up the volume (to about 23) when the front speakers just stopped working. I checked the amp and its not getting any power. All of the fuses (the amp and under the hood) are good, and the ground is also fine (I checked the resistance). I don't know what the problem is and its really irritating. Somebody please help me
NorthWest,
Michigan
Post Number: 4521 Registered: Dec-03
| Posted on Monday, October 11, 2004 - 02:14 pm: |
use a DMM and check for voltage at the amplifier check remote trigger voltage too make sure you don't have a short in the speaker wiring, such as a speaker terminal grounding out against the door frame or something. go through start to finish and check for problems in a linear manner.
| Posted on Monday, October 11, 2004 - 03:22 pm: |
ok the remote turn on had proper voltage, but I'm gettin nothin at the power wire (I havent checked the speaker wires yet) |
| Posted on Monday, October 11, 2004 - 04:33 pm: |
just checked again... there is correct voltage at power wire also i tried using the fuses from the 1200.1 amp, but that didnt do anything if there was a short, then the fuse would blow right? i guess it has to be something inside the amp??? |
NorthWest,
Michigan
Post Number: 4526 Registered: Dec-03
| Posted on Monday, October 11, 2004 - 09:23 pm: |
if there was a short the amp could have internal thermal protection that's tripping and shutting off the amp. that was why I'd mentioned it as worth checking. the amp may just be damaged.
| Posted on Thursday, October 14, 2004 - 03:22 pm: |
ok i tried turning the amp on without the speaker wires hooked up and it still didnt do anything... i'm going to take the amp apart myself before having it professionally repaired if it would be possible to diagnose any obvious problems that could cause it to stop working... glass (or anybody else) could you possibly give me a link or short explanation so i can know what obvious problems to look for inside a class A/B JBL power series amp? thanks |
NorthWest,
Michigan
Post Number: 4582 Registered: Dec-03
| Posted on Thursday, October 14, 2004 - 03:28 pm: |
http://www.bcae1.com/repairtutorialcdinfo.htm worth the price and then some.
| Posted on Sunday, October 17, 2004 - 06:07 pm: |
Thanks, but i dont think I have the necessary equipment or time (college student >_<) to properly fix the amp myself... its still under warranty by JBL so I guess I'm going to call them and figure out how I can get it serviced, unless it would be better to replace it... have amp serviced or replace it??? thanks again |
NorthWest,
Michigan
Post Number: 4819 Registered: Dec-03
| Posted on Monday, October 18, 2004 - 12:51 pm: |
go with warranty repair. for sure. btw, your college, if they have any sort of EE program, should have everything needed for fixing an amp in one of their labs.. hehe scopes, meters, probes, soldering and de-soldering equipment..
Silver Member Username: Fishy
Tamarac,
FL
Post Number: 582 Registered: Sep-04
| Posted on Tuesday, October 19, 2004 - 04:19 am: |
Hehe... yep back before store bought ones were readily available I almost built a 120v 1/2 farad stiffening cap from "free" stuff layin around in a EE storeroom. Only problem was it woulda been big enough to use as a personal flotation device. You'd probably get plenty of help fixin that thing. They love it when students take an interest.
-Fishy |
NorthWest,
Michigan
Post Number: 4867 Registered: Dec-03
| Posted on Tuesday, October 19, 2004 - 09:58 am: |
heck I built my first oscilloscope from a "Bell & Howell" kit. man that was a while ago.
