Thread: Help! Sony head unit |
New member Username: A2001
Cambridge UK
Post Number: 1 Registered: Oct-04
| Posted on Sunday, October 10, 2004 - 05:34 pm: |
Hello folks Really need your help with this one! I have just installed a Sony head unit however each time the engine is switched off all pre-set radio stations disappear. Could this be a faulty wire adaptor? Please help it's driving me mad! |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 649 Registered: Apr-04
| Posted on Sunday, October 10, 2004 - 09:36 pm: |
Mabey you are pressing something wrong, sounds like something in the HU memory, or something needs to be set differently, read up on the instruction manual. I highly doubt its a faulty wire, because there is no wire on the harness for pre-set radio. |
Webbfeet Unregistered guest |
| Posted on Wednesday, October 13, 2004 - 03:17 am: |
As a guess: from reading the other sony forum - is the red wired to the ignition, and the yellow directly to the battery? If it is opposite, you would be losing your memory due to no power. |
