Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > What can I do with a 75x2 amp?
Author Thread: What can I do with a 75x2 amp?
Username: Danania1
I have a 75x2 amp. I cannot power all 4 speakers with it can I? What can I do with it? Use it to power the back speakers? Thanks for all advice.
Username: Danania1
Post Number: 7
anyone?
Username: Chevy_for_life
Post Number: 49
is it just me or dose like nobody answer any questions on here anymore..
Username: Fishy
Tamarac, FL
Post Number: 445
If your amp is stable to two ohms and all four speakers will be runnning at the same frequencies just hook up two of the speakers from each side in parallel. You won't have any front/rear fader ability but it'll work.
If your talking about subs then its a different story.
-Fishy
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > What can I do with a 75x2 amp? [ « Previous ] [ Next » ]
