Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Clifford concept 200 car dead
Author Thread: Clifford concept 200 car dead
I have a 96 impala i bought recently that has a clifford concept 200 installed. the alarm kept giving false alarms almost every time i set it. i had a known good concept 20 alarm i pulled from a car i sold. I switched the brain of the alarm (big mistake) needless to say it didn't work but now when i plug the concept 200 in i get nothing no alarm lights can't arm and worst of all my car won't start no ignition lights starter won't crank or anything i've checked all fuses. PLEASE HELP!! thanks in advance
Username: Jeremyc
Kunsan Afb
South Korea
Post Number: 102
Take it to a clifford dealer and see what it would cost to fix it, and put your name under the waranty. I promise it will be worth it. If you have any other questions check out this post http://forum.ecoustics.com/bbs/messages/4/14368.html
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > Clifford concept 200 car dead [ « Previous ] [ Next » ]
