Thread: Which amps to get? kicker? |
New member Username: Rob36
Post Number: 2 Registered: Oct-04
| Posted on Thursday, October 07, 2004 - 07:19 pm: |
ok so its like this, im buying 2 Alpine SWR-1241D Type R 12" subs, and i need to buy amps for them. Ive heard good things about kicker, and im wondering; is kicker the way to go? If so, can you reccomend a specific amp to pump the power out of these subs? if theres something better quality/ same price or lower than kicker, please tell me too |
Post Number: 3 Registered: Oct-04
| Posted on Thursday, October 07, 2004 - 07:26 pm: |
two 04 Model KICKER KX450.2 AMP 2 Channel 450W, one for each sub would be overdoing it right? so down a notch i think cause they put out 250 and the subs are only 300 |
