Thread: Simple Answer To My Confusion... |
Bronze Member Username: Lamf77
Post Number: 11 Registered: Sep-04
| Posted on Thursday, October 07, 2004 - 01:42 pm: |
Okay, I have the two rca cables off the head unit back to my 4 channel amp which is now powering my front speakers and my subwoofer with the rear channel (until I can get a second amp for the sub). I had the rear speakers directly wired to the amp, but disconnected them to hook up the subwoofer. Can I reconnect the rear speakers back to the direct output from the head unit. Using the head unit to power the rear speakers? Help, Please, and Thank You! Mike |
Gold Member Username: Jonathan_f
GA
Post Number: 2136 Registered: May-04
| Posted on Thursday, October 07, 2004 - 03:01 pm: |
Yes. |
Post Number: 12 Registered: Sep-04
| Posted on Thursday, October 07, 2004 - 03:21 pm: |
Thank You!!!! |
