Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Need help with a wiring diagram! powe...
Author Thread: Need help with a wiring diagram! powering 2 amps
Username: Big_l
Surrey, Surrey
England
Post Number: 25
basically i need to split a power cable from the battery to a mono amp and a 4channel amp in my boot, i don't want to run two power cables.
what gauge cable will i need to use? and other important factors like that...
thanks for any help guys!!!
Username: Boopers
Lima, Ohio
United states
Post Number: 130
best bet depending on the size of amps would be a 4 gauge power wire run to a distro block that splits into 2 8 gauge power wires in your boot
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Need help with a wiring diagram! powe... [ « Previous ] [ Next » ]
