Thread: Bridging my amp for subs? |
New member Username: Heresy209
Post Number: 10 Registered: May-04
| Posted on Thursday, October 07, 2004 - 01:32 am: |
I was wondering how to bridge my amp for my subs. The amp: Eclipse 3242(Fujitsu Ten) 4x110w at 4ohm, 2/3/4channel The subs: 2 12" Boston Acoustic RS12's (no idea of the wattage and stuff...) Headunit: Alpine CDA-7894 26w or 27wx4 RMS Any help would be appreciated. |
Bronze Member Username: Noblemobile
Van Nuys,
CA
Post Number: 15 Registered: Sep-04
| Posted on Thursday, October 07, 2004 - 02:04 am: |
you need to post more info. need what type of amps & subs to help you. |
Bronze Member Username: Heresy209
Post Number: 11 Registered: May-04
| Posted on Thursday, October 07, 2004 - 10:25 am: |
Eclipse 3242 Amplifier contain following functions : 50W x 4 Channel 0.04% THD at 4 Stereo, 20-20,000Hz @ 12.5V ChannelFlex Crossover on Front Amplifier, Rear Amplifier and PreAmp Adjustable High-Pass Frequency (50-200Hz or 1.5-6kHz) Adjustable Low-Pass Frequency (50-200Hz or 1.5-6kHz) Double-Sided PCB High-Current, High-Speed Output Devices High-Efficiency, High-Energy MOS FET Power Supply Audiophile Grade Component Selection Intelligent 7-Way Discrete Protection Circuitry Music Reproduction with Low Distortion & Ultra-Low Negative Feedback Efficient Cooling with Low-Profile Heatsink Multi-Mode Configuration Stereo/Mono Switch Hopefully something in there that'll help, I'll find the info on the subs when I get home.
Post Number: 12 Registered: May-04
| Posted on Friday, October 08, 2004 - 04:29 pm: |
This is the only info I can find on the subs. Boston Acoustics RS-12: 4/8ohm 400w RMS 95 dB |
