Thread: I think my amp exploded... |
New member Username: Biohazrd
Post Number: 1 Registered: Oct-04
| Posted on Wednesday, October 06, 2004 - 11:51 pm: |
I just finished re-wiring my system. I noticed that my speakers automatically cut out after the volume reached a certain point. I then proceded to go to the amp, and do something stupid, I cranked the gain. I saw a flash, and smoke started POURING out of the amp, the fuse was blown, but I dont have another to check if the amp still works. What could cause this to happen in the first place? |
Juggalo Jeff Unregistered guest |
| Posted on Thursday, October 07, 2004 - 12:39 am: |
Bad wiring possibly on ur part or short circuit the amp is most likely toast |
Post Number: 2 Registered: Oct-04
| Posted on Thursday, October 07, 2004 - 12:44 am: |
Like, a bad ground? |
| Posted on Thursday, October 07, 2004 - 12:47 am: |
not sure what did u rewire though?
Bronze Member Username: Noblemobile
Van Nuys,
CA
Post Number: 16 Registered: Sep-04
| Posted on Thursday, October 07, 2004 - 02:06 am: |
You blew some resistors from bad wiring. Will cost you about $65 to get it fixed. Apms only smoke from a bad wire job. |
New member Username: Pete0403
| Posted on Thursday, October 07, 2004 - 07:35 pm: |
I did something like that after (stupidly) running JBL GTQ360 bridged into a 1.3Ohm load for a few years until it finally blew. Check your spkr wiring with a voltmeter. Check the resistance this'll tell you right away if you have a short. If you want to fix the amp, you'll pay an arm and a leg. You can open it up and try to fix it yourself (you've got nothing to lose). More than likely only one side of the amp (unless it's 1ch mono) will be blown. You'll be able to tell wich transistors are blown if it was smoking. just write the #'s down from the other side and go to a parts store and ask them. I was quoted $150-200 CAD to fix my amp, I fixed it myself for $30 and it's back in action now. (at a 4 ohm load) I knew very little about electronics except the basics. Sorry to write a book...hope it helps if you decide to go this route. |
