Thread: MTX Thunder 801D or 1501 D |
New member Username: Skeet2331
Muncie,
IN
Post Number: 7 Registered: Sep-04
| Posted on Wednesday, October 06, 2004 - 05:07 pm: |
I was thinking about getting either the MTX thunder 801D or the 1500D but i didn't know if the 1500 would over power them...it is rated at 750 X 1 at 4 ohms...the subs take 800 rms.. 2 MTX 8000 10's...and i didn't want to underpower them with the 801D b/c it is rated at 400 X 1 at 4 ohms..What does everyone else think. Is the 801D to little or is the 1500D to big? |
Muncie,
IN
Post Number: 8 Registered: Sep-04
| Posted on Saturday, October 09, 2004 - 07:34 pm: |
does anybody have a different option like a 2 channel amp possibly? |
Silver Member Username: Decde
Post Number: 127 Registered: Sep-04
| Posted on Saturday, October 09, 2004 - 07:50 pm: |
ur better underpowering it than overpowering it... How much watts rms are u overpowering them by?? |
Unregistered guest |
| Posted on Monday, October 11, 2004 - 07:10 am: |
the 801d and 1501d are 2 channel amps and an 801d will pound the hell out of 2 mtx 8000 10's |
New member Username: Tree23780
Post Number: 2 Registered: Oct-04
| Posted on Tuesday, October 19, 2004 - 09:38 am: |
i have a 1501D pushing 2 15 l5 solobarics. |
Bronze Member Username: Mu_forever
Post Number: 24 Registered: Jul-04
| Posted on Tuesday, October 19, 2004 - 12:04 pm: |
if your subs can run at 2 ohms the 801d will do 800 watts wired in parallel to the mono channel of the amp. |
Post Number: 3 Registered: Oct-04
| Posted on Thursday, October 21, 2004 - 01:02 am: |
trust me that 1501D will pound the hell out of them 10s to. you will be pushing 1000 watts per speaker, the 1501 is 1500 rms.. But thats at 2 ohms. |
Gold Member Username: Jonathan_f
GA
Post Number: 2419 Registered: May-04
| Posted on Thursday, October 21, 2004 - 01:18 am: |
An 801D will power your subs perfectly, 1500 is pushing your limits. I think you're looking at the peak rating, the MTX 8000 10" subs are 400W RMS, at a 2 ohm load an 801D is perfect for them as it'll give each sub 400W RMS. |
