Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Amp Explanation, Help !!!
Author Thread: Amp Explanation, Help !!!
Username: Swantlaphoenix
I have a 95 Jeep wrangler. This summer I installed an Alpine 9835 deck and new speakers (4" Infinity Kappa 42.5i in the sound bar, and 4x6 Infinity Kappa 462.5 in the front. Well the Infinity's are great but now I need some bass badly. I've decided on the subs I want: 2 10's Infinity Perfect 10.1d's in a Q-logic Sealed box. The RMS on the subs are 350 watts. Now I dunno which amp to get to power these? The only thing I could really find was the Alpine MRP-M350. Im not looking to under power or over power them. I'm not sure to rather 2 channel or mono? x 1 x2? I know running them in parallel will give me 2 ohms. Thats about all I understand. AHAHAH HELP Please! !!! THANK U
opps excuse me they are not d's. They are single voice coils
Username: Fishy
Tamarac, FL
Post Number: 346
If they are 4 ohm single voice coil subs you'd wire em in parallel to get a 2 ohm load.
Most 2 channel amps won't work to well in this situation so I'd recommend a monoblock that gets it best power at 2 ohms.
Gimme a price range and I can make some recommendations.
Here's some basic ones.
Cheap used - JBL 600.1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18796%26item%3D5724227019 %26
Cheap new - Soundtream Rub500/2(2 ohm stable mono 2 ch)
http://www.acaraudio.com/product_info.php?manufacturers_id=26&products_id=453
BEST DEAL used - Soundstream 702(matches RMS perfect at 700w)
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=4950%26item%3D5723886397% 26
http://www.soundstream.com/sub/owner_manual/Rub5027021002.pdf - specs
BEST DEAL new - Xtant A6001T
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=64573%26item%3D5723596530 %26
Moderately priced new - MTX 801d
http://www.acaraudio.com/product_info.php?manufacturers_id=30&products_id=649
High End used - JL Audio 500/1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=79827%26item%3D5724442902 %26
High End New(no warranty tho) - JL Audio 1000/1
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5724483407 %26
High End new - Zapco C2k-3.0x(665 watts bridged)
http://www.acaraudio.com/product_info.php?manufacturers_id=27&products_id=515
good luck :-)
-Fishy
Username: Bigjay
Post Number: 34
I am actually considering a similar setup in my 2004 chevy pickup except in my case I am going to do the infinity Kappa Perfect 12.1d which are DVC. I am going to wire them parallel each so I can get a 2ohm rating. The amp I like is the RF T10001b. It is rated at 750RMSx1 @ 2ohms. Is this going to be a problem since the two subs together are only going to equal 700x1@2ohms. I don't want to blow the subs but I wasn't sure if that extra 50RMS would cause a problem with the subs
Yea.. Most of these amps you recommend are like 500 RMS and such? I thought you were supposed to match the RMS of the subs so in the long run you dont wear them out?
Username: Fryguy
Nova Scotia
Post Number: 255
I have a nice explanation of the difference between resistance and impedance http://fryguy.ca/Forum/viewtopic.php?p=37#37 that should hely you understand what it's all about.
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Amp Explanation, Help !!! [ « Previous ] [ Next » ]
