Thread: Hifonics NX750D |
atreyu rock Unregistered guest |
| Posted on Wednesday, October 06, 2004 - 12:00 am: |
is the Hifonics NX750D 1 ohm stable? |
Silver Member Username: Boopers
Lima,
Ohio
United states
Post Number: 114 Registered: Jul-04
| Posted on Wednesday, October 06, 2004 - 12:05 am: |
check the site, but I believe the 1000 and 1500 are 1 ohm stable, not the 750
Bronze Member Username: Comet345
Orlando,
FL
Post Number: 68 Registered: Sep-04
| Posted on Wednesday, October 06, 2004 - 11:32 am: |
what does that mean if it were or were not "1 ohm stable" |
Lima,
Ohio
United states
Post Number: 119 Registered: Jul-04
| Posted on Wednesday, October 06, 2004 - 11:59 am: |
1 ohm stable means that it can handle an ohm load as low as 1 ohm. but I believe that the 750d is only stable down to 2 ohms |
