Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Sub wiring help!!! 2 or 4 ohm
Author Thread: Sub wiring help!!! 2 or 4 ohm
Username: Bfedro427
Post Number: 9
I have 2 Kicker CVR12s at 4 ohms a piece. I was considering buying a monoblock amp to run these. If i wire these in parallel i will get a 1 ohm right, and if i wire them in series i will get a 4 ohm load right? which one would yall reccomend. Also im trying to find a JBL amp to run these for under 300 bucks. Please let me know what you find.
Username: Boopers
Lima, Ohio
United states
Post Number: 112
if you run 2 4 ohm speakers parallel you get a 2 ohm load, series would give you 8 ohm load
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Sub wiring help!!! 2 or 4 ohm [ « Previous ] [ Next » ]
