Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > SPL, SQ, whats the difference?
Author Thread: SPL, SQ, whats the difference?
jared S
what's the diference between them an which one is better?
Username: Jonathan_f
GA
Post Number: 2040
SPL is sound pressure level, how loud it gets. SQ is sound quality, how accurately your system portrays how the material was originally intended to sound. One isn't necessarily better than the other, it's all in your preference. The good thing is that you don't always have to sacrifice one to get the other, unless you're an extremist.
Username: Stanleyc
Post Number: 13
I am new to car audio, but spl and sq apply to audio besides cars. I believe spl is the sensitivity. The higher the spl, the more efficient it is in producing higher amplitudes (volume). As for sq, I am not sure, but I believe it stands for sound quality. As for which is better, it depends soley upon the listener. Some people like their system loud while others like it accurate, etc. Personally I prefer SQ over SPL, but SQ is not something that is rated in the specs you see online. You have to go out and listen for yourself to judge SQ.
PS. If any of the above mentioned are completely inaccurate, just ignore it. This is just what I believe so far after 3 days worth of research on car audio. =)
Username: Stanleyc
Post Number: 14
Cool, yea listen to Jonathon. He's the man to trust. He must have posted it while I was typing all that up. =)
Username: Stanleyc
Post Number: 16
O yea, how do I edit a post? I keep thinking of more stuff to ask after posting. For good SQ how should speakers be placed? Location of tweeters, mids, etc...
GA
Post Number: 2043
I answered your thread. What kind of speakers do you have/plan to get?
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > SPL, SQ, whats the difference? [ « Previous ] [ Next » ]
