Thread: What amp to use for 2 12" Alpine Type-R's? |
Bronze Member Username: Almost2asian
Post Number: 19 Registered: Sep-04
| Posted on Tuesday, October 05, 2004 - 06:05 pm: |
What amp should I use for two Alpine Type-Rs? They're rated at 300 RMS each. I'm looking to spend about 200-300 dollars, ebay prices, on an amp. Would a mono or 2-channel amp be better? |
Silver Member Username: Fishy
Tamarac,
FL
Post Number: 327 Registered: Sep-04
| Posted on Tuesday, October 05, 2004 - 08:14 pm: |
Depends on which model/impedance Type-R you have. Dou you have the dual 4 ohm voice coil, dual 2 ohm, or what? -Fishy |
Post Number: 20 Registered: Sep-04
| Posted on Tuesday, October 05, 2004 - 11:16 pm: |
well, i haven't gotten them yet, which should i get? and why? what are the advantages to each? |
