Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Can I bridge two DVC Subs on a 2 chan...
Author Thread: Can I bridge two DVC Subs on a 2 channel amp
Username: Wobble
I have 2 Volfenhag DVC 12s and a 600w Volfenhag amp, (2 channel). Is it possibel to bridge both subs without hurting my amp?
Juggalo Jeff
are they dual 4 ohm or dual 2 ohm
Username: Wobble
I think they are 2 but i'm not sure. let me check
Username: Wobble
nope they are 4 ohm per coil
Juggalo Jeff
u wont be able to bridge them safely then if they are 2 ohm on that amp
Juggalo Jeff
alright then u can bridge them also how do u have them hooked up right now?
Username: Wobble
right now they aren't I wanted to know if I could bridge them before i hooked them up. The guy I bought them from told me I could, but I just wanna make sure.
Juggalo Jeff
go to rockfordfosgate.com that will show you how to wire them
Username: Wobble
Yea I got that scematic. It just shows how to wire the subs. I know how to do that, I need to know if I can bridge them on the amp
Juggalo Jeff
yea you can
Username: Jonathan_f
GA
Post Number: 2056
Yep. being dual 4 ohm, wire the voice coils in series, then wire both subs parallel to the bridged channel.
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Can I bridge two DVC Subs on a 2 chan... [ « Previous ] [ Next » ]
