Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Looking for an amp
Author Thread: Looking for an amp
Username: Bigjay
Post Number: 26
I am looking for a good quality amp for my system. What I need is an amp that is 2 channel and will run at approx 375W per channel at 2 ohms. Or I need a mono amp that runs 750W RMS x1 at 2 ohms. Any suggestions are helpful. Thanks.
Username: Insearchofbass
Post Number: 799
my good ole standard try the mtx 6500d or the mtx 801d the 6500d is the same amp just version before the 801d and is slightly cheaper cost wise...can be had for bout $200 shipped on ebay
Username: Bigjay
Post Number: 27
oops, my goof, I wrote down wrong. The subs ar rated at 350W RMS each so that would put the rating at 700RMS total on the amp for a mono amp wired at 2 ohms. With these being rated higher, will that cause a problem with possibly blowing the subs?
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Looking for an amp [ « Previous ] [ Next » ]
