Thread: Amp and sub wiring quest. |
Silver Member Username: Johnnylemoine
LaPlace,
Louisiana
United States
Post Number: 129 Registered: Aug-04
| Posted on Monday, October 04, 2004 - 09:20 pm: |
i have a JL12W3D4 and a Rockford P3001. Its 300x1 at 2ohms rms. my sub's vc's are run in parallel to get a two ohm load, but my quest is how to hook it to my amp. The amp has 2 sets ao terminals, 2 pos. and 2 neg. But its a mono block amp. do I hook up a pos. on one side and neg. on the other side of the amp like bridging or just hook up the pos. and neg. that are side by side? Hope yall can understand and help me. |
LaPlace,
Louisiana
United States
Post Number: 136 Registered: Aug-04
| Posted on Monday, October 04, 2004 - 11:48 pm: |
hey |
LaPlace,
Louisiana
United States
Post Number: 146 Registered: Aug-04
| Posted on Tuesday, October 05, 2004 - 12:57 am: |
yo |
Silver Member Username: Southernrebel
Louisiana
Post Number: 224 Registered: Mar-04
| Posted on Tuesday, October 05, 2004 - 01:03 am: |
if its a mono amp, then it just has two terminals (it acts like a distro. block so you can hook up more than one sub easily) ...like the JBL bp600.1 just hook it you to one (-) and (+) |
LaPlace,
Louisiana
United States
Post Number: 148 Registered: Aug-04
| Posted on Tuesday, October 05, 2004 - 01:08 am: |
ok thanks, I just wondering why it two terminals on a mono block, i never saw that before. |
Silver Member Username: Fishy
Tamarac,
FL
Post Number: 313 Registered: Sep-04
| Posted on Tuesday, October 05, 2004 - 01:16 am: |
like this http://home.comcast.net/~guppyrig/wsb/media/322068/site1052.JPG The actual positions of the positive and negative terminals on that sub are probably reversed from the diagram. I just put em that way to make it easier to draw the wiring. good luck -Fishy |
Tamarac,
FL
Post Number: 314 Registered: Sep-04
| Posted on Tuesday, October 05, 2004 - 01:18 am: |
There's two terminals on that monoblock for convenience sake. It can make it easier to run a pair of speakers in parallel that way. Both "positives" and "negatives" are common to each other. -Fishy |
LaPlace,
Louisiana
United States
Post Number: 150 Registered: Aug-04
| Posted on Wednesday, October 06, 2004 - 07:10 pm: |
Thanks dude. |
