Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Amp recommendation for infinity subs?
Author Thread: Amp recommendation for infinity subs?
Username: Factor067
I need a recommendation to power (2) 1230W Infinity Reference 12'' They are rated at 300 RMS and impedence of 4 ohms. I want to get atleast under 200$ if i could.
Username: Jonathan_f
GA
Post Number: 2016
JBL 600.1 would work well.
Username: Factor067
where can i get one of the for the cheapest price? or is there an easier other brand that is just as good that i can get for a good price on ebay?
Username: Fishy
Tamarac, FL
Post Number: 295
Ebay is probably the only place you will find the 600.1.
If you hurry:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5723427686 %26
If you'd rather have somethin new you can pick up a discontinued Soundstream Rubicon 500/1 for $160 here:
http://www.acaraudio.com/product_info.php?manufacturers_id=26&products_id=457
I picked up a 300/2 for $140 shipped a couple months ago and am totally satisfied with the way it performs. That 500/1 may not be as powerful as the 600.1, but it should be a bit cleaner since its class A/B.
Plenty of other stuff out there. If you could go listen to a few and find somethin you like you might be able get a really good deal on it via ebay.
-Fishy
Username: Factor067
any more recommendations?
Home > Message Board > Car Audio > Amplifiers > Archive through October 10, 2004 > Amp recommendation for infinity subs? [ « Previous ] [ Next » ]
