Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > 4*6 speakers
Author Thread: 4*6 speakers
atreyu rock
i got 4*6 speakers in my front doors and i want to put some good component speakers in there but i cant find any, would a 6" componant fit in the slot?
Username: Elecgenius
La Puente, Ca
United States
Post Number: 39
nope. u gotta cut it up. just get a cutter and cutemm up. the speakers come with a blue print anyways made to scale. by the way 4 * 6 's soun like crap----except mb quarts.
Username: Tafkam
Texas
Post Number: 92
What about Infinity Kappa 4x6? do they fall into the sound like crap catagory? Hope not I bought 'em just have not had them put in yet......
La Puente, Ca
United States
Post Number: 81
nah man--infinity is top of the line stuff. theyll be good sounders dont worry about it
Username: Glasswolf
NorthWest, Michigan
Post Number: 5277
the kappa 4x6 plates are about the best ones I know in that size.
if ya want separates you could also go 5.25" or 6.5" if you don't mind cutting for custom installs
Home > Message Board > Car Audio > Speakers > Archives - 2004 > Archive through November 17, 2004 > 4*6 speakers [ « Previous ] [ Next » ]
