Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > Deck has no sub out or remote turn on...
Author Thread: Deck has no sub out or remote turn on...Work with mono amp?
Username: Dtone
I bought a JVC KD-G700 and i noticed it didn't have any sub line out. I dont mind not having music on my rear speakers as it is a dodge dakota, but do i need the remote turn on? Can I even hook my amp up to this? Thanks!
Username: Jamesdunn
Post Number: 27
just hook the remote tern on wire to ur switch of ur car and it will tern the amp on when the car switch is on.
Username: Fishy
Tamarac, FL
Post Number: 248
Look for the power antenna lead on that h/u. That will work just fine as a remote turn on for your amp.
-Fishy
Username: Koz1031
Monticello, In
United states
Post Number: 189
like fishy said, there is a blue wire or a blue wire with a white stripe, also if it's a new h/u it showld have a marker on it. that's the wire to run to the remote.
Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > Deck has no sub out or remote turn on... [ « Previous ] [ Next » ]
