Thread: Best Amplifier for the money |
New member Username: Bigjay
Post Number: 9 Registered: Sep-04
| Posted on Friday, October 01, 2004 - 10:21 am: |
I need a 2 channel amp that will run 300W per channel at 1 ohm. Any suggestions and a good amp that won't cost a ton of money
Bronze Member Username: Forcesofchaos
Post Number: 46 Registered: Sep-04
| Posted on Friday, October 01, 2004 - 12:43 pm: |
i dont think think you will find a two channel amp that supports 1 ohms at least for cheap, maybe around 300-500 you could if your willing that much, coulud you get a like a 2 ohm amp and just parrallel/serial connect them to make 2 ohms? |
Bronze Member Username: Chevy_for_life
Post Number: 26 Registered: Sep-04
| Posted on Friday, October 01, 2004 - 01:42 pm: |
What do you concider cheap buddy? |
Silver Member Username: A3forme
Post Number: 313 Registered: Sep-04
| Posted on Friday, October 01, 2004 - 08:31 pm: |
What is it that you're trying to power? Maybe there are other options. |
