Home > Message Board > Car Audio > Head Units > Archive through November 04, 2004 > Pre-amp voltage? Glass?
Author Thread: Pre-amp voltage? Glass?
Username: Audiophile
OFallon, MO
Post Number: 94
Which is "better" 2v, or 4v? Im looking at buying an Alpine CDM-9823 unit for my 95 talon, but I'm not sure as to whether I should spend another 150 bucks and just get the CDA-9830...(the CDA-9825 doesn't fit)
Any help is appreciated. Thanks in advance!
OFallon, MO
Post Number: 95
Uhh, hello? Anyone?
Seriously, its just a 2 letter answer. "2v" or "4v". I will be running a single mono amp on a subwoofer output if that's any help to you.
OFallon, MO
Post Number: 96
Ok come on...someone please answer me...
Juggalo Jeff
4 volt is better there is a less chance of any unwanted noise in the system
Jer
Also, pre-voltage is basically the amount of volts that are kicked out into your amp. The higher, the better.
Username: Jonathan_f
GA
Post Number: 2135
4V is better. 2V won't necessarily generate audible noise in your system, but it's more likely to. Also, with 4V allows your gains to be set lower, meaning the noise floor is lower b/c the amp doesn't generate noise into the system by turning the gain up.
OFallon, MO
Post Number: 100
Thanks for all the help guys. Especially Jer and Jonathan
Home > Message Board > Car Audio > Head Units > Archive through November 04, 2004 > Pre-amp voltage? Glass? [ « Previous ] [ Next » ]
