Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > My Stock HU pre amp or speaker level?
Author Thread: My Stock HU pre amp or speaker level?
Username: Jeep59
Los Gatos, CA
I have a stock Grand Cherokee 5.9 HU that came with a multi channel amp (Infinity) under the seat. Im replacing the amp and cant tell if the HU output in pre-amp or speaker level.
How do I tell? I have voltmeters etc.
Thanks
Username: Pat_l
Tucson, AZ
Post Number: 625
Just clarifing, your asking how to tell if your HU has Pre-amp (RCA) outputs or hi-lo speaker level converted. Most to no stock HU have pre-amp outputs, you can check by seeing if there is anything on the back that looks like you can plug RCAs into. Usually stock, amps that come with the vehical just have a bucnch of small wires, not anything like RCAs and thick power wire. So to replace that amp you will mostlikely have to re-run a power and ground, remote and RCAs, RCAs can be run two ways, using exsiting pre outs (if the HU has them) or buying a seperate Hi-lo converter, which converts the frequencies of 2 speakers (left and right both the + and -'s). This is done by just splicing the 4 wires on the stock wiring harness. Here is what you would need (of course by looking on the internet you can find them cheaper).
http://www.tune-town.com/installation/line_out_reducers.asp
Username: Fishy
Tamarac, FL
Post Number: 242
I'm not a big fan of thsoe hi/lo line converters. They add distortion and can lead to a significant loss of frequency response. If you can find some speaker preouts under say 4 volts I'd think you be better off soldering them up to some female rca plugs.
If you have a wiring diagram and can isolate the correct speaker preouts measure the a/c voltage across say right front pos/neg. If its under about 4 volts(or greater depending on your amp) at 3/4 volume then you should be good.
Maybe Jonathan can recommend a good line converter but my experience with the things hasn't been great, course I'm kinda picky.
-Fishy
Username: Jeep59
Los Gatos, CA
Yep the Stock HU has the standard Chrysler wire harness on the back running to the amp, then to the speakers. My new Amp has pre-amp ins(RCAs) and Speaker level ins (molex plug). I just dont know which in to use on the amp. I suppose I could hook up a speak direct to the HU outs and if it makes enough noise I assume speaker level out? But how loud should it be?
Username: Fishy
Tamarac, FL
Post Number: 243
I've always tried to avoid speaker level inputs like the plague. I'm not really familiar how they work on an amp(step down transformer or what).
We need some advice from Sir Jonathan.
-Fishy
Username: Jeep59
Los Gatos, CA
So Fishy you think if right off the HU im getting <4V at 3/4 volume I should be ok with using the amps Preins?
That I can check. I know some of the better new HU's have ~4V preouts anyway.
Username: Fishy
Tamarac, FL
Post Number: 244
lol, yeah that was my gauge, but there's a few amps that can handle crazy amounts of voltage. It sure would be easiest just to use the hi level inputs on your amp but I'm not positive your SQ won't suffer as a result. Again I'm not sure how the hi level inputs work on amplifiers. If they just use a stepdown transformer like like those line converters then I'd think you lose some sound quality.
If it were me I'd put in a "loud" cd and start measurin voltages and stuff, but I like messin with those kinda things.
-Fishy
Username: Jonathan_f
GA
Post Number: 1936
Most high level inputs sound like crap compared to an RCA line. Sorry. The high levels of an amp are (usually) the same as a line out converter, just a step down transformer. Problem is, with an LOC you need to convert to low level as soon as possible for least noise, but it still limits freq. response and increases noise and distortion. If you must use the factory head unit, soundgate makes good LOCs.
GA
Post Number: 1937
Oh yeah, make SURE to use high quality, twisted pair RCAs, and connect the LOC as close as you can possibly get it to the head unit.
Username: Jeep59
Los Gatos, CA
Right but Im banking on not needing the LOCs, if the HU out voltage is low enough.
My new amp is a JL Audio e6450. Has input sensitivity adjusters on the preins.
Dont know how much VAC the amp preins can handle.
GA
Post Number: 1942
8 volts RMS.
GA
Post Number: 1943
You'll still need an LOC, by the way.
Username: Jeep59
Los Gatos, CA
Why would I need the LOC?
GA
Post Number: 1947
The head unit's amp will put out at least the same voltage as your charging system at full power, somewhere between 12-14.4V. If the amp uses a transformer (such as the Alpine V-drives) voltage will be even higher than that. That's why an LOC is needed, or use high level inputs (which I don't recommend)
Username: Jeep59
Los Gatos, CA
So I guess your convinced that the HU in my jeep, which is stock connected to a stock infinity amp, is feeding the infinity amp speaker level signals (12+V)?
GA
Post Number: 1950
Oh, by the way that 12-14.4V will be the peak voltage, RMS would be about .707 of peak (theoretically) so 8.5V minimum RMS signal coming from the head unit. When the car is running, it'd be over 10V RMS more than likely.
GA
Post Number: 1951
Most factory head units use speaker levels, more than likely that's the case with your Jeep.
Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > My Stock HU pre amp or speaker level? [ « Previous ] [ Next » ]
