Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > Independance
Author Thread: Independance
davidfrost
Hi, What is independance is it the way you wire your up your sub or is it the sub?, or i also heard that 4 Ohms was to do with double voice coil and 2 Ohms with a single voice coil correct me if im wrong, cheers......
Username: Decde
Post Number: 81
LOL
My friend, i think you are talking about impendance here... You are right for the ohms.
Can someone with a little more knowledge than me explain plz.
pacavelizzzz
david u got ur info a bit wrong..subs either come in dual ohm voice coil or single voice coil (SVC)if u got dual 4 ohm subwoofer, u can wire ur subs to get 2ohm or a 8 ohm load on ur amp... it also depend in ur amp chekc out its spec it will tell u if its 1, 2 or 4 ohm stable but most amps are 4ohm stable just the class D (digital) amp go down to 2 ohms or the top quality go down to 1 ohm stable. just check out their specs they will tell u.. hope it helps
david1111
so..... your saying that its to do with the wiring and you can hook up your sub with any inpendence from the amp? lol sorry for being stupid
thanks a lot
Username: Decde
Post Number: 90
lol
don't worry david =)
I was like that too when i started
davefrost
lol! im stupid but we all gotta start from somewhere
Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > Independance [ « Previous ] [ Next » ]
