Thread: Blue Thunder amp Question???? |
| Posted on Tuesday, September 28, 2004 - 12:13 pm: |
MTX Blue Thunder 3002 750W 2 Channel Does anyone know anything about this amp? The specs or where I can get them? Is this a good amp? Thanks |
New member Username: Skeet2331
Muncie,
IN
Post Number: 4 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 01:27 pm: |
Are you looking at the one that is currently on ebay for $40 it would be a great amp for that money http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem%26%26item%3D5722687968&ssPageName= STRK:MEWA:IT |
| Posted on Tuesday, September 28, 2004 - 01:37 pm: |
Yes, But I need to be able to run 2 12" L5's with it, do you think this is big enough?? Thanks!!!! |
Muncie,
IN
Post Number: 5 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 03:12 pm: |
The L5's are rated at 450 rms if i'm not mistaking? But keep in mind that the MTX is underrated on all their amps. So i would say that the amp would power 2 L5's with no problem |
New member Username: Jaackdeth
Burnett,
WI
United States
Post Number: 7 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 04:32 pm: |
Thanks!!!! |
