Thread: Suitable amp |
anon777 Unregistered guest |
| Posted on Tuesday, September 28, 2004 - 10:09 am: |
Hi, What would be a suitable amp to run 2 Sony XSL121P5's? Oh and please dnt criticize as i have already purchased them!!! Any help regarding the amp would mbe much appreciated |
Bronze Member Username: Decde
Post Number: 54 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 10:27 am: |
Ok, for these subs, what i read is that they have good sq, but not so good spl, i'm not saying their bad, just saying the truth :P They have 350 watts rms each, so you are looking at 700watts rms. Tell me how much you have to spend on an amp. |
anon45345 Unregistered guest |
| Posted on Tuesday, September 28, 2004 - 10:44 am: |
nah, dnt worry about cash just i cant find a amp which is 2 channel and rated at 350 watts RMS X 2 at 4 Ohms, u got any ideas? cheers |
anaon554 Unregistered guest |
| Posted on Tuesday, September 28, 2004 - 05:02 pm: |
oh yeh and what is 4 OHM and 2 OHM is it the rating of the sub or is it how you wire it? cheers
