Thread: Neone no anything about JL |
New member Username: Mikeycaldarone
North Providence,
Rhide Island
United States
Post Number: 10 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 09:09 pm: |
My friend is gettin 2 10" W6V2's any suggestions for an amp. If you find one with links please leave links. |
Bronze Member Username: Sixstar
Post Number: 56 Registered: Aug-04
| Posted on Monday, September 27, 2004 - 09:47 pm: |
Lots to choose from. How much cash? What DVCs does he have? |
Bronze Member Username: Mikeycaldarone
North Providence,
Rhide Island
United States
Post Number: 11 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 09:54 pm: |
he has about 500 to spend |
North Providence,
Rhide Island
United States
Post Number: 12 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 10:43 pm: |
and if u have en websites that have cheap ones please send the link |
Gold Member Username: Jonathan_f
GA
Post Number: 1886 Registered: May-04
| Posted on Tuesday, September 28, 2004 - 12:03 am: |
W6v2s are dual 4 ohm subs. The newer Kicker 850.2 would work well, wire the coils in series, then the subs in parallel. Bridge the amp and it'll put out 850 watts RMS. I saw them here: http://www.woofersetc.com/product.asp?0=337&1=338&3=2481 Very solid amp with great SQ. |
New member Username: Ericaraudionut
Post Number: 6 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 12:54 am: |
no offense jonathon, but unless this dude can get a hell of a deal on it, kicker is way overpriced.do kicker amps even state a damping factor? you kids will blow money on anything these days. |
Post Number: 61 Registered: Aug-04
| Posted on Tuesday, September 28, 2004 - 01:05 am: |
1. I didn't realize that the W6v2s were all 4ohm. Sorry for not checking. 2. Eric- He just posted a link where the amp is going for $447. And its a very good amp. You can also get an Orion 8002. The go for quite a bit cheaper than the Kicker in most cases, and are also very good. |
Post Number: 9 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 01:18 am: |
Orion in my past experience is great stuff, if you can save money, save it dude. a watt is a watt. don't buy into a name. Ever heard of viper, clifford, avital, or ads? A company called directed electronics makes them. same company that makes orion. it's good stuff. |
GA
Post Number: 1893 Registered: May-04
| Posted on Tuesday, September 28, 2004 - 01:26 am: |
If you don't like the recommendation, then post your own. It was just my opinion on what would work well. He stated a $500 budget, and that amp fit within that category on the link I gave him. It's a very well built amp with great SQ and underrated in power. I'm 36, by the way, not exactly what you'd call a kid . |
| Posted on Tuesday, September 28, 2004 - 01:28 am: |
one more thing before i go, if you have the money to spend soundstream is to die for. they have some on that same link posted earlier. if you want underrated power this stuff is great.notice damping factor is stated by them. anything greater than 250 is very good. |
Bronze Member Username: Ericaraudionut
| Posted on Tuesday, September 28, 2004 - 01:34 am: |
jonathon, didn't mean to insult you, I sell/install this stuff for a living (3yrs). I just get tired of seeing kids throw their money away on a name. g-night everyone. |
GA
Post Number: 1895 Registered: May-04
| Posted on Tuesday, September 28, 2004 - 01:36 am: |
No, no offense taken at all, I wasn't insulted. I was just curious about what alternative you may have had in mind. |
North Providence,
Rhide Island
United States
Post Number: 13 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 07:20 am: |
i might jus buy a 10" W7 abd run it wit a JL amp 500/1 would that be a good system? Make suggestions if u think it wuld be a good system |
GA
Post Number: 1902 Registered: May-04
| Posted on Tuesday, September 28, 2004 - 03:19 pm: |
I think it'd be good IF you want to spend the money. It's all in personal taste. Also, tell your friend to look on ebay for the older KX800.2, it'll power the subs well and is cheaper than the amp I posted above. |
