Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Which amp better
Author Thread: Which amp better
Username: Forcesofchaos
Post Number: 32
MA AUDIO M683i 800 Watt 2 Channel Amplifier!
Selectable Bass Boost (0db, 6dB, 12dB)
Selectable Crossover: LPF, FLAT, HPF
50Hz - 250Hz Low Pass Filter
50Hz - 250Hz High Pass Filter
2 x 200W Rms @ 4 Ohm Stereo
2 x 400W Rms @ 2 Ohm Stereo
1 x 800W Max @ 4 Ohm Bridged
Fuse Rating: 30A x 2
Dimensions: 13" L x 9.5" W x 2" H
or the kicker, kx600.1
600watts
second amp is 300, first amp you can get it for about 100 used i think maybe
Home > Message Board > Car Audio > Amplifiers > Archive through February 08, 2005 > Which amp better [ « Previous ] [ Next » ]
