Thread: Too much bass not enough sound from inside speakers |
New member Username: Adrian757
Newport News,
VA
Post Number: 2 Registered: Aug-04
| Posted on Monday, September 27, 2004 - 05:53 pm: |
Hey, i just got (2) 12' woofers and a 2 Channel amp installed. I still have my factory radio. The amp has a remote to control the bass but its still too much bass. When i turn the volume up the speakers inside the car not loud enough but the bass is. Does anyone have any suggestions for me????? |
Silver Member Username: Wrestlertreece
Post Number: 115 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 06:22 pm: |
First of all What kind of Woofers did you get and Amp what brand and watts |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 154 Registered: May-04
| Posted on Monday, September 27, 2004 - 08:00 pm: |
man I always upgrade the door speakers ands stuff b4 I do my bass. Bass is easy to get but detail and clarity is the key. If you wanna keep it simple replace your fron and rear speakers and get a nice 4 channel amp to compliment your bass line. |
Newport News,
VA
Post Number: 3 Registered: Aug-04
| Posted on Monday, September 27, 2004 - 08:43 pm: |
sub brand M.A 800 watt amp by Boss |
New member Username: Skeet2331
Muncie,
IN
Post Number: 3 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 09:29 pm: |
you should always upgrade the factory speakers and deck before you start installing subs. everyone thinks you can just a bass and it will sound all the better, not knowing it just makes it sound worse b/c you can't hear the highs...install the door and rear speakers before you add the subs. don't forget to get tweeters that make a huge difference to complaiment the lows |
Bronze Member Username: Sixstar
Post Number: 58 Registered: Aug-04
| Posted on Monday, September 27, 2004 - 09:51 pm: |
Turn the bass off the head unit if you have any on. And fade your speakers to the front. Might help a little. And then go get the rest of the system upgraded when you have the cash. |
