Thread: 2 or 4 channel amp? |
New member Username: 90crx
Sacramento,
Ca
Usa
Post Number: 2 Registered: Sep-04
| Posted on Sunday, September 26, 2004 - 11:52 pm: |
I wanna run 4 speakers of an amp. They can handle each can handle 100 rms. So do I actually need a 4 channel or will using a 2 channel work, just wire it 2 left and 2 right? |
Silver Member Username: Joe718
Brooklyn,
NY
Post Number: 147 Registered: May-04
| Posted on Monday, September 27, 2004 - 12:19 am: |
I would use a 4 channel but a 2 channel could work just make sure each channel is 2 ohm stable... |
Silver Member Username: Fishy
Tamarac,
FL
Post Number: 229 Registered: Sep-04
| Posted on Monday, September 27, 2004 - 03:00 am: |
Depends on the application. Are these subs? If so what are their impedances(like 4 ohm etc)? Technically you only need ONE channel to run a set of subwoofers. -Fishy |
Sacramento,
Ca
Usa
Post Number: 3 Registered: Sep-04
| Posted on Tuesday, September 28, 2004 - 03:53 am: |
just components and 6.5's there 4 ohm speakers |
