Thread: PowerAccousics? |
| Posted on Sunday, September 26, 2004 - 10:43 pm: |
are Their amps anygood? |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 609 Registered: Apr-04
| Posted on Sunday, September 26, 2004 - 11:25 pm: |
NO GOOD |
Juggalo Jeff Unregistered guest |
| Posted on Monday, September 27, 2004 - 12:00 am: |
i have the lt1440 its a decent amp |
| Posted on Monday, September 27, 2004 - 12:18 am: |
It's pretty decent if you want it to blow up afterwards.... |
| Posted on Wednesday, September 29, 2004 - 12:20 am: |
blow up no not quite |
New member Username: Brmsnowboarder
Brooklyn Park,
Minnesota
United States
Post Number: 3 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 09:33 am: |
I have a 1140lt and it has been in my truck pushing two 10" MTX Thunder 8000. I have not had any problems with the amp. There are no heat issues and the amp has more than enough power for the subs. |
Brooklyn Park,
Minnesota
United States
Post Number: 4 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 09:34 am: |
I have a 1440lt and it has been in my truck pushing two 10" MTX Thunder 8000. I have not had any problems with the amp. There are no heat issues and the amp has more than enough power for the subs. |
Silver Member Username: Zacdavis~
Post Number: 117 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 04:48 pm: |
i'm doing a 160db in a crx right now, i have 4 3000d power acoustik(spl) amps running at .4 ohms. they are rated only to 1ohm but i run them HARD at .4 and they've never failed me, i competed all summer long and i have NEVER had a problem with them. btw, the class i mainly compete in is 901-1800 superstock and i can only use two amps in that class and i do consistent 156's. power acoustik make bad azz AMPS! |
New member Username: Mememegetgetget
Post Number: 7 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 05:05 pm: |
I've had 2 Power Acoustic amps and both worked well untill they were stolen in other words they drove my subs enough to get my system noticed by the wrong people..... |
Bronze Member Username: Chevy_for_life
Post Number: 24 Registered: Sep-04
| Posted on Wednesday, September 29, 2004 - 05:18 pm: |
HA HA that would suck so bad dude |
