Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > Powering two adire shivas???
Author Thread: Powering two adire shivas???
Username: 50amps
Ontario
Hi I was wondering if a memphis 16mc 500d putting out a solid 500 watts RMS (250 to each sub) could properly power two shivas in a sealed box, 1.5 cubes for each sub?
Username: Decde
Post Number: 49
U can get better than a memphis amp.
But yes the memphis amp will do the thing.
Check out the mtx amps.
Username: Sixstar
Post Number: 60
Id go with a bit more power if you can actually.
Username: 50amps
Ontario
Thanx for the posts. Would the kicker KX 600.1 be able to power the shivas to full excursion with 2 cubes for each sub?
Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > Powering two adire shivas??? [ « Previous ] [ Next » ]
