Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > When using more than 1 amp
Author Thread: When using more than 1 amp
Username: Udloze
NSW
Australia
Post Number: 8
just say i was using two amps does that mean that i have to get a electronic crossover or what??
thanks
Username: Pat_l
Tucson, AZ
Post Number: 598
No you dont need one.
Username: Udloze
NSW
Australia
Post Number: 10
so i just use the pre outs one to each amp
Username: Pat_l
Tucson, AZ
Post Number: 605
Yes, get a Y adapter(s) and y them out to each amp. And same with remote wire to
Username: Udloze
NSW
Australia
Post Number: 16
thanks. im designing a sub box do u know of a site where i might be able to get hints on how to make it better
HI I HAVE A AMP BUT THE AMP TITS THE BASS THE AMP PROTECTION LIGHT TURNS OFF ,& I HAVE TO TURN OFF THE RADFIO FOO &AND ON IN ODER TO RESED THE AMP , IS THERE ANYTHING THAT I CONNECTED WRONG ,, THANKS /, MANUEL
Concerned Reader
First learn/use proper grammer, spelling , and don't use all caps (equal to shouting). Then repost your message so we can understand exactly what you issue is. Thanks!
Username: Decde
Post Number: 67
LOL
HAHA!....I did not get much of that either.
Home > Message Board > Car Audio > Amplifiers > Archive through October 04, 2004 > When using more than 1 amp [ « Previous ] [ Next » ]
