Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Can some one tell me what kind of amp...
Author Thread: Can some one tell me what kind of amp i need?????
Username: Dabeast34
Post Number: 27
i have just bought two 12" Cerwing Vega V-max subs, i am really new to all of this car audio stuff and i have no idea what kind of amp that i need. Here is the site with all the information on the subs that i have
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=13950
so if u could look at this site and all the info about the subs and tell me what kind of amp i need for two of these subs
-Thanks-
Username: Fishy
Tamarac, FL
Post Number: 210
If you want to go an inexpensive route you can try and get a used JBL BP600.1 off Ebay.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5721652524 %26
If you'd like a new amp I listened to this one on a pair of Eclipse hybrids and was pretty impressed.
http://www.acaraudio.com/product_info.php?manufacturers_id=30&products_id=649
If you'd like to go a lil more hi end you could impress your friends with
http://www.acaraudio.com/product_info.php?manufacturers_id=27&products_id=1166
This amp is discontinued and is probably your best deal on a new item. People say that Soundstream is not what it used to be since the company was sold but this is a fairly older design. I have a Rubicon 300/2 and am completely satisfied with its performance. It sounds great on my MB Quart Q's and will push my 10w3d2's at a fairly good clip as well.
http://www.acaraudio.com/product_info.php?manufacturers_id=26&products_id=457
There's plenty of other good reasonably priced amps out there like Kicker, etc. which I'm sure others can recommend. These are just the ones I'm most familiar with.
-Fishy
Username: Fishy
Tamarac, FL
Post Number: 211
Oh don't just automatically assume those are the best prices. I didn't spend any time looking for the best deal. Try some other places like Woofers Etc and Millionbuy.com.
-Fishy
Username: Udloze
NSW
Australia
I've got two jbl subs and a 1000watt jbl car amp and I'd like to connect them to my home stereo could you please help me out and explain in detail how I should go about powering the car amp? Thanks
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Can some one tell me what kind of amp... [ « Previous ] [ Next » ]
