Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Do Speakers Truly Perform Better At 1...
Author Thread: Do Speakers Truly Perform Better At 1 Ohm
Username: Danny_b777
Bradenton, Florida
Post Number: 8
Is it ture that a speaker will perform better at 1 ohm, or is 1 ohm just giving it more power.
Username: Fishy
Tamarac, FL
Post Number: 207
No, speakers perform best when properly matched to an amplifier. If that amplifier happens to be 1 ohm stable then I'd say yes, it will in general deliver more power to that speaker than one that was say 2 or 4 ohms.
-Fishy
Username: Jonathan_f
GA
Post Number: 1839
Amps running at 1 ohm will have higher distortion, worse damping, more heat, and less headroom than the same amp running at 2 or 4 ohms.
Bradenton, Florida
Post Number: 10
Thanks
Bradenton, Florida
Post Number: 11
If I get a mono amp and hook it up, will it automaticly fuction at 1 ohm, or is there a special way to hook it up to bring it down to 1 ohm. And what happens if you cross the negative and positive on a 2 channel amp (runnin the positive from one channel to the positive and the negative from the second channel to the negative),is that parallel?
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Do Speakers Truly Perform Better At 1... [ « Previous ] [ Next » ]
