Thread: Amplifier connection |
Unregistered guest |
| Posted on Friday, September 24, 2004 - 05:14 pm: |
Hi people, I was just curious as this car i have just purchased has a Kenwood KDC-3024 CD player fitted, i was just curious if i could attatch an amplifier for a sub onto it. Im sorry if im being stupid but im not sure what im doing and need some help!! I think it has 8 different speaker connections on the back thanks very much matt |
| Posted on Friday, September 24, 2004 - 06:40 pm: |
oh yeh and sorry what is a pre out????? thanks |
Bronze Member Username: Forcesofchaos
Post Number: 28 Registered: Sep-04
| Posted on Friday, September 24, 2004 - 07:18 pm: |
yah you could get a amp connected into that easily the pre out on the deck allows you to connect it to the ampilfier. |
Silver Member Username: Pat_l
Tucson,
AZ
Post Number: 587 Registered: Apr-04
| Posted on Friday, September 24, 2004 - 11:23 pm: |
Yeah, your headunit makes it super easy to connect a amp to it. The pre-outs for RCA's on the back of your HU will allow you to just plug in RCA cords out from the HU and into the AMP with no problem. If your HU has pre-outs (which it does) then it probably has a AMP remote wire hanging out (on the wiring harness), this makes it even easyer, all you do is connect your AMP's remote wire to that and you be set (as long as you have power and ground to your amp). |
| Posted on Saturday, September 25, 2004 - 07:59 am: |
cheers, your help much appreciated :D |
