Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Need sub wiring help
Author Thread: Need sub wiring help
Username: Northerncomfort
Sudbury, Ontario
want to wire two 4 ohm svc subs to my amp,my amp is 80wx2 @ 2 ohm
160wx1 @ 4 ohms
if i want to bride the amp i can only achieve a 2 or 8 ohm load with my 2 subs(series or parallel)
the amp is stable at 4ohms bridged....
What should i do
Username: Boopers
Lima, Ohio
United states
Post Number: 102
if you wire the vc series and the subs parallel that would give you a 4 ohm load
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Need sub wiring help [ « Previous ] [ Next » ]
