Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > 2 Audiobahn AW151T 15" Subs. What Am...
Author Thread: 2 Audiobahn AW151T 15" Subs. What Amp Do I Need?? over or equal watt?
Detest Boss
I am thinking of buying 2 Audiobahn AW151T 15" subs. Each are 1000 watt subs with 2 ohm. So I need a 2-channel AMP.
My friend tells me that if I get an AMP that is a little overpowered, it will sound a lot better.(I.E.-2400watt AMP is better then a 2000watt AMP for 2 1000watt subs.)
IS THIS TRUE? CAN YOU TELL ME THE BEST AMP I SHOULD GET?
Your mom in the can
I herd that too. Underpowering is bad, equal power is good, but i dont know about over powering to make it better.
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > 2 Audiobahn AW151T 15" Subs. What Am... [ « Previous ] [ Next » ]
