Thread: Please Help!!!!! |
| Posted on Thursday, September 23, 2004 - 02:56 am: |
Will a JL 1000/1 be able to push two 12w7? Or should i just get two JL 500/1? Please Help!!!! |
Silver Member Username: Fishy
Tamarac,
FL
Post Number: 170 Registered: Sep-04
| Posted on Thursday, September 23, 2004 - 03:10 am: |
They'd probably sound almost exactly the same with a slight edge to the twin 500/1's. I think they are a little more "underated" and would probably have a little better damping factor running at a higher impedance, but with the JL's switching voltage rails I'm not sure. Jonathan would know for sure of course. Has anyone thought "alternator" yet? -Fishy :P |
Gold Member Username: Jonathan_f
GA
Post Number: 1799 Registered: May-04
| Posted on Thursday, September 23, 2004 - 03:24 am: |
Better the single 1000/1 IMO. You'd have to match the gains of the dual 500/1s perfectly for best SQ, which is very hard to do since each amp/sub will be a little different due to tolerances. Damping difference wouldn't really be noticeable, or worth mentioning for that matter. Think of the JL regulated amps more as 1.5 ohm stable amps capable of putting more power into higher impedances instead of amps that don't add power with less impedance. Difference of the amps at different impedances isn't a lot. Plus, the 1000/1 will be cheaper and take up less space, and won't require a distribution block and two ground points. |
| Posted on Thursday, September 23, 2004 - 03:33 am: |
Thanks Fishy and Jonathan is there any other amp that will push does sub's. |
Tamarac,
FL
Post Number: 172 Registered: Sep-04
| Posted on Thursday, September 23, 2004 - 03:42 am: |
Jonathan knows. -Fishy :P |
| Posted on Thursday, September 23, 2004 - 08:27 pm: |
Jonathan is there any other amp that will push does sub's? |
GA
Post Number: 1812 Registered: May-04
| Posted on Thursday, September 23, 2004 - 11:00 pm: |
Yeah, any amp that'll do about 1500W RMS into 1.5 ohms. Depends totally on your budget. JBL 1200.1 would work. |
| Posted on Thursday, September 23, 2004 - 11:46 pm: |
Jonathan what about a PD3 amp!!! |
GA
Post Number: 1820 Registered: May-04
| Posted on Thursday, September 23, 2004 - 11:53 pm: |
Which amps are you talking about there? You're not talking about the Boss PD-3000 amps are you? |
| Posted on Friday, September 24, 2004 - 01:04 am: |
My bad i was talking about a Phd2.... 2000 W x 1 into 4 ohms 2000 W x 1 into 2 ohms 1000 W x 1 into 4 ohms Mono block - single channel amplifier
| Posted on Friday, September 24, 2004 - 01:07 am: |
OR the EARTHQUAKE PH-D3 ~5000 Watts Maximum Power ~3000 Watts x 1 into 1 ohm ~2600 Watts x 1 into 2 ohm ~1300 Watts x 1 into 4 ohm |
