Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > SMALL amp for rear fill. Jonathan?
Author Thread: SMALL amp for rear fill. Jonathan?
Username: Fishy
Tamarac, FL
Post Number: 149
I'm thinking upgrading my pro MOS-2050 to to an Xtant 1001dx and unfortunately I'm gonna lose space for my Rubicon 300/2 for fill. I've found a spot under my rear seat where my Class A 50II will fir but unfortunately one channel is posessed on that amp. I found an old D60 on Ebay, but its just that, OLD.
I was wondering if anyone makes a really small amp anymore(less than 8 1/2 x 7 x 2 1/4 inches).
The only amp I've found small enough so far is this Xtant:
http://www.caraudiomag.com/testreports/0308cae_xtant/
Runnin rear fill mono is cool right? and this thing is really dinky and would match my other Xtant stuff. Only problem is the price($300+).
Just wondering if anyone had any suggestions before I break down and buy this old Soundstream D60.
thanks
-Fishy
Username: Southernrebel
Louisiana
Post Number: 191
hey fishy,
you wanna sell that Rubicon 300/2?
Username: Fishy
Tamarac, FL
Post Number: 157
Sure, I just won the big Xtant. As soon as I get my mits on that thing the Rubicon's an orphan.
I paid like 140 for it new a month ago. I still have the box, manual, receipt, and even the stickers. Its only been used for rear fill so should just about be broken in by now. :P
Drop me a line: guppyrig@comcast.net
I've never sold anything via mail so bear with me.
-Fishy
[note] I'm still lookin for a small amp. I slept through the D60 auction. :-(
A D100, Class A 50 or 40, or Granite 60.2 would fit as well.
How come no1 makes "small" amps anymore? H/U's get too powerful or somethin?
Username: Jonathan_f
GA
Post Number: 1790
For rear fill, mono is actually more desirable than stereo is. So any amp that would put out the power you want into an 8 ohm bridge would work. That Xtant would be good, and I doubt you'll find many that put out more power for the size.
Username: Fishy
Tamarac, FL
Post Number: 169
I don't need much power. I was using a Class A 50II until one channel started acting up. That Xtant is absolutely the only modern day amp I've found that will fit but I don't think it will work either. It looks like it only has one input rca which means no internal summing amp, which means I'd only be able to run "one side" off my xover. This would sound stupid. I guess I could build a lil summing preamp, but that sure seems like a lot of effort just for a bit of fill.
Arggggg! Guess I either get the 50II fixed or wait for another baby Soundstream to show up on Ebay. I tried off the h/u and was appalled by the SQ. :P
-Fishy
Username: Fishy
Tamarac, FL
Post Number: 188
Well I've got the summing right and left channel thing solved, well kinda. My 4180c provides a summing option for its front/rear outputs and since its bridged(front=left, rear=right) it'll give me a summed left and right output.
The only problem is I lose fader control at the head unit and rear level control at my FRX 456. I'm not sure I even need that xover anymore w/o my PPI. Should I yank that thing out? It seemed like my imaging/stereo separation improved after I installed it. My Alpine has 4 volt preouts and the 456 is 8 volts max out.
Oh and what happens when you bridge an amp which has intermittent problems on one channel? Will I lose output completely if the one channel goes? or just half the power.
I guess I could run the rear fill off the one "good" channel until I get somethin mo betta.
thanks
-Fishy
Username: Fishy
Tamarac, FL
Post Number: 189
I was just wondering if the problem is on the "input" side of things bridging might bypass it. The Class A 50 has no summing amp and uses only one input for mono operation.
-Fishy
GA
Post Number: 1814
Bridging would eliminate all sound. It combines the transistors, one being pos. and one being neg. anyway, you'd kill one side, it'd be the same as disconnecting a speaker wire. As simple as a Class A amp is, I don't think it'd be too difficult/expensive to get yours fixed, and it seems it's your best route.
Username: Fishy
Tamarac, FL
Post Number: 196
Yeah its weird. It acts just like a bad connection and seems to quit working and come back on for no apparent reason.
I've a lil extra time on my hands and was thinking about ordering that amplifier repair tutorial cd here:
http://www.bcae1.com/
and maybe take a crack at fixing amps in my spare time. I've got some basic background knowledge and kinda thought it would be fun(plus a good excuse to by some neat equipment). You don't happen to know anyone who's purchased that CD do you. That site is huge and that guy seems really well informed.
-Fishy
GA
Post Number: 1818
I personally don't know anyone, but Glasswolf knows the author of that site. He's very knowledgeable, I'm sure the cd is well worth it. If you've ever worked on electronics, amps aren't terrible, I haven't cracked your particular amp, but being a Class A I bet it's not bad at all. It could be as simple as a solder point from what you describe, and a lot cheaper and better SQ than that Xtant Class D. Some audio shops will fix amps for you or be willing to ship the amp to the company for repair if you're not comfortable with it after you crack the amp.
Username: Fishy
Tamarac, FL
Post Number: 197
I've got basic some basic soldering skills and know a lil about oscilloscopes and such from some of the acoustics and electronics labs I had back in the day. I've designed and built logic circuits(on breadboards), but am not very familiar with the linear stuff. I did manage to get some free op amp replacement samples from Texas Instruments for an old PPI Xover so I know how to read a data book. Diagnosing and troubleshooting is another story.
Thats where I need help.
-Fishy
GA
Post Number: 1823
As far as transistors go, you can test those with a voltmeter. Depends on if they're silicon or germanium, but they maintain an internal voltage, around .7V for silicon and .3 for germanium. You can start there. Look for bad solder points, fried electronics to start with. It's only for one individual channel, so it can't be horrible. I'd crack the amp first and see, you may see what it is right off and not even have to order the cd.
Username: Fishy
Tamarac, FL
Post Number: 199
I cracked it awhile ago looking for burnt resistors etc. but since its an intermintent thing I don't know where to start. It might bench just fine but start cuttin in and out when I get it back in the car. When it works it works great. I wonder if there's any thermal protection circuitry. I forgot what a thermistor looks like. Ok, now I haveta go look inside it again. lol, great.
-Fishy :P
GA
Post Number: 1828
Check the connection to the amp's speaker terminals, it may be as simple as that.
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > SMALL amp for rear fill. Jonathan? [ « Previous ] [ Next » ]
