Thread: Electrical Problems |
New member Username: Rmike21561
Maryland
Post Number: 10 Registered: May-04
| Posted on Wednesday, September 22, 2004 - 11:35 am: |
Ok, I am having trouble with some options in my 2002 explorer. I already had to have the module that controls the automatic lights replaced...not cheap. Also, I have gone through three new ignition switches (the engine still runs even when the key is off and out.) The Ford dealer thinks it has to do with my system. I am no expert @ this but I know how to wire a system. (Alpine Head Unit, Hifonics 1500D Amp, and 2 Type R 12 subs) Is there anyone that has ever heard of this happening? |
Bronze Member Username: Zacdavis~
Post Number: 77 Registered: Sep-04
| Posted on Friday, September 24, 2004 - 03:13 am: |
i think maybe its had a remote starter installed at one time and its activating somehow however the lights thing could be due to a shorted out "dimmer" wire behind your deck |
Bronze Member Username: Rmike21561
Maryland
Post Number: 12 Registered: May-04
| Posted on Friday, September 24, 2004 - 09:31 am: |
Did some research. No remote starter. Someone told me that the alternator might not be putting out enough amps to run everything with the stereo causing certain units to malfunction. Although, the stock alternator is a 130 amp alternator. The Hifonics amp is 120amp max. So, before I get a new alternator does anyone think this could be the route of my problems? |
