Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > HELP with two amps please!!
Author Thread: HELP with two amps please!!
Forgetting about the subs I might use these with, just straight up, what would be the better all around amp: Kicker KX600.1 or Memphis 16MC 500D? I know these are pretty comparable amps but what one would any of you guys pick in particular and why? Thanks very much
Username: A3forme
Post Number: 249
They are both solid amps. The KX600.1 will actually put out more like 700-750w RMS (typical birth sheet). while I don't really know if Memphis under-rates or is right on, but will put out less power most likely. I wouldn't have a problem using either, would just depend on what subs I was using, which I would choose.
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > HELP with two amps please!! [ « Previous ] [ Next » ]
