Thread: Jonathon................advice please |
Bronze Member Username: Angelofdeath132
Iowa
Usa
Post Number: 50 Registered: May-04
| Posted on Tuesday, September 21, 2004 - 06:53 pm: |
think i've made my final decision as far as amp and subs: 2 Rockford Fosgate HE2 4112 2 ohm DVC's powered by a JL 500/1 amp. sound o.k.? |
Iowa
Usa
Post Number: 51 Registered: May-04
| Posted on Tuesday, September 21, 2004 - 07:32 pm: |
actually, everyones thoughts would be helpful! ;) |
Bronze Member Username: Wrestlertreece
Post Number: 64 Registered: Sep-04
| Posted on Tuesday, September 21, 2004 - 07:42 pm: |
Make up your dang mind man... |
Gold Member Username: Jonathan_f
GA
Post Number: 1751 Registered: May-04
| Posted on Tuesday, September 21, 2004 - 10:45 pm: |
Sounds good, it's just what you like. Weigh out all your options and listen to as many subs as possible, whatever you like best that is reliable (which the stuff you listed is) will work for you. That combination will work well together, so as long as you like the equipment all is well. The subs may be a bit underpowered, though, depending on the type of box you plan to run. |
Iowa
Usa
Post Number: 52 Registered: May-04
| Posted on Wednesday, September 22, 2004 - 07:39 pm: |
sealed box
