Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Need a good AMP. to power subs.
Author Thread: Need a good AMP. to power subs.
Username: Jamesdunn
Post Number: 9
I have 2 Boss 10in Subs they are rated at 500 watts rms and 1000 watts max. I want a good amp that will give them full power with 500 watts going to each 1 when they have a 1 Ohm independec. Thanks for any help.
Username: Wrestlertreece
Post Number: 54
I've been told that Boss Are CRAP and are Over rated...
Visitor#78
If you give those thing 500W true rms, they'll melt.!!!! And that's no lie!
Username: Jamesdunn
Post Number: 10
well then what should i get that isnt that expencive no more than 200 for a pair that is 500 watts rms.
Username: Fishy
Tamarac, FL
Post Number: 171
If they have dual 2 ohm voice coils like I think then this would work:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&category=18797%26item%3D5721652524 %26
Assuming this too wouldn't be too much power.
-Fishy
Home > Message Board > Car Audio > Amplifiers > Archive through September 26, 2004 > Need a good AMP. to power subs. [ « Previous ] [ Next » ]
