Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > PowerAcoustik 2300W RMS/3000W & 2 pio...
Author Thread: PowerAcoustik 2300W RMS/3000W & 2 pioneer 750rms/2000max
Username: Forcesofchaos
The Black Widow BW2150 4-Button Vehicle Security System
* Two 4-button Transmitters with Labeled Rubber Buttons
* Built-in Relays for Starter Disable and Flashing Parking Lights
* Door Lock Outputs
* Plug-in Electronic Shock Sensor w/Light Impact Response
* LED Status Indicator
* Emergency Override Switch
* 125dB 6-tone Siren
* Auxiliary Output
* Dome Light Output
* Horn Honk Output
* Panic Mode
* Valet Mode
* Tamper Alert
* Automatic Sensor Bypass for Defective Zones
* Programmable Trunk Disarm Feature
* Programmable Active/Passive Arming
* Programmable Automatic Rearming
* Programmable Passive Locking
* Programmable Ignition Controlled Lock/Unlock
* Programmable Extended Pulse Lock Output
* Programmable Double Pulse Unlock Output
* Programmable Chirp Delete
* Remote Chirp Delete
* Non-volatile Memory
Any good?
http://www.etronics.com/product.asp?stk_code=blabw2150&rpc=296&catid=297&store=
If not maybe anotherone at this site? cheaper the better
Sorry delete this one
Home > Message Board > Car Audio > Security Systems > Archive through December 02, 2004 > PowerAcoustik 2300W RMS/3000W & 2 pio... [ « Previous ] [ Next » ]
